printfactory
CAN SOMEONE PLEASEHEP ME FIGURE THIS OUT?
Does anyone know steps to recalibrate the motor?
This error could be generated for many reasons like failure to load and unload the plates or low vacuum pressure or...... What you will need to do is to describe the problem. Was there a plate jam during load/unload process? If you only feel motor calibration will resolve the issue, then this can be found under tools....Avalon lf control ..... servo motor calibration of UNIDIAG software. Hope this will help!CAN SOMEONE PLEASEHEP ME FIGURE THIS OUT?
We figured out that the motor end up failing, may I ask if you know an sources where I could buy avalon agfa lf output motor CG+034520502 ?
Thanks for your help in advance
