Agfa Avalon LF Thermal .. Laser Problem
Aguila-x-
Hello guys
The problem are those lines that shows in the entire plate..
It happens from time to time and it doesnt matter the kind or size of plate that i choose.
Also, when this happens, it starts with lines that are hardly seen, but the next plates are notorious like the photo im uploading.
Does anyone have an idea or suggestion for me to try?
Im still learning to use and handle this CTP
Thank you very much
Armya Inc
Hello guys
I'm way too scared cause of this problem. View attachment 4560
Thank you very much
Do not be scared and do not be worried!
I can help you with any kind of problems with lines on the plates as well as Laser issues , but I will need more clear pictures from the lines on the plates to be sent to me a.s.a.p.
Please contact farshad@armyaservices.com.
Aguila-x-
I can help you with any kind of problems with lines on the plates as well as Laser issues without putting my foot in your site, but I will need more clear pictures from the lines on the plates to be sent to me a.s.a.p.
Hello
Thank you very much for your answer.
I just sent you an email
Armya Inc
Hello
Carlos,
I have got your email. I have installed many Avalons LF and know the machine inside out. I will guarantee 100% the issue will be resolved . Just follow my instructions in the email. You shouldn't be doing that yourself. The Laser might be damaged. Let me fix it for you. Rest assured. Sleep Well.
Yoana
Hello friends, we have a CTP Avalon N4 that presented an electrical short circuit and we have already replaced the power card but the fault persists and now, the technical support indicates that I must change the memory board, who has had experience on this?
the device turns on but does nothing, that is, the screen stays in "checking memory" and does not start.
I appreciate your help and suggestions
ernierad
Hello guys
I'm way too scared cause of this problem. View attachment 227714
Thank you very much
Did you get your problem fixed.
Koenig & Bauer Video
Canon 2022
The Video You Really
Need To Watch
View The Video
