Agfa Avantra 44 input jam error
68Shelby
Yesterday they ran a piece of film through the machine and it said it ran out but it actually had a few feet left on it and the image setter as usual just ran out the extra but stopped about a foot short with that error. We turned off the processor and back on to get it to finish running it out but it never stopped. It just runs for a while then gives us a input jam error. The switch on the end of the dryer seems to be fine and I'm guessing the input sensor is what's in the bridge but not sure how to check and see if it's working. Any ideas. Thanks.
ChrisZ
Bridge sensors you can diagnose with AVdiag, processor with AndroDiags.
Got software and cables?
Chris
Armya Inc
Have you tried the processor in offline mode? Have you noticed the same result? Isn't it the process signal from imagesetter is being sent to processor?
The manual clearly explains the sensors and how they will be checked.
Good luck .
Farshad
What else did you do?
Good luck.
68Shelby
Figured it out. The switch where the film enters the processor was stuck down. Didn't even know there was a switch there. Now if someone could tell me how to get to it to clean it up and look at it so it doesn't stick again.
Armya Inc
Get to it and clean it. Easy as thatthat if you feel the sensor has issue. But how about the buffer.
Could be the brake on the buffer motor. Have you tight the screw on it? It could be loose.
What About Profitability?
Canon
What about Profitability?
Offset yields new advantages
Read All About It
