Air Humidity > Static > Paper Curl
natty
Hi All,
With the new Re-humidifier in the new KM's i thought that it could be possible to create an offline sort of solution that does the same thing, such as an air humidifier just near the output tray of the machine ?
Is anyone using Air Humidifiers near their press for this reason and is it effective in reducing or eliminating static and paper curl ?
Were I am located the humidity is usually around 0-10% year around. We run 2 humidifiers by our Ricoh trying to keep at least 20-25% humidity. It helps a little with paper curl but mainly our print quality improves a little when humidity is higher.
