Angle sets for HPS
Hello,
I have a fast question I am hoping someone can help me with.
We have adopted a custom set of screen angles of:
Cyan at 105 degrees
Magenta at 75 degrees
Yellow at 30 degrees
Black at 45 degrees
How could I go about making this custom angle set of 105, 75, 30, 45 available in the 'Optimize for angle set:' pulldown menu located in the 'Harlequin Precision Screening Options' dialog box?
Is there a configuration file I can edit or something of this type?
Hi Tony,
You can't modify the UI, but you can write a Page Feature that does what you want. Put the following into a file in the "SW/Page Features" folder and then select it in your Page Setup. You might need to subtract 90 from the 105, but I can't remember exactly on that one - I've not tested it, but it should work subject to that.
%!HMR
/ScreenAngles [ 105 75 30 45 ]
/Password 0
>> setsystemparams
%end of !HMR
Regards,
Andy.
Andy Cave,
Chief Executive Officer,
Hamillroad Software Limited.
.:Hamillroad Software | Products | FirstPROOF:.
.:Hamillroad Software | Welcome:.
page features can be combined, but you need to be careful.
If your existing feature starts with << and ends with >> you would put them together with a << at the beginning and a >> at the end.
If your existing feature ends with "exitserver" you'd need to put them in separate but consequtive, so to speak, exitserver end line << etc.
In most cases combining will work, but the syntax is important.
