anilox recommendation
ar17
our flexo CI press arrives this 3rd quarter of the year. would like to get valuable inputs what anilox sizes and bcm i would be needing for printing light substrate paper and film. this is all waterbased flexo printing. hope to get response if i have 8 first options this anilox, what will be the lpi or the bcm most appropriate for this substrates.
thanks
Slammer
I suppose you would first have to determine what screen ruling you want to print, say a 70ppcm screen; would be 180 lpi, a low ball ratio screen to anilox would be 1:5, gives you 900 pits per inch.
ar17
thank you sir. my follow up question is since we are offset printer printing at 150 to 175 lpi, can i still apply thes same screen rulings when printing same jobs in flexo? what will be the standard lines per inch in my plates for my process colours when i print it in flexo? thanks
Slammer
As Cornishpastythighs says, a banded anilox maybe a good purchase.
You can still use your 150 to 175 lpi without much ado, what RIP will you be using? Just don´t forget your bump ups and you should be fine, however all screen forms commonly used in Offset may not be practical, stick with round for the beginning
What About Profitability?
Canon
What about Profitability?
Offset yields new advantages
Read All About It
