Any way to calibrate/adjust Morgana Autocreaser?
gazfocus
I’ve recently bought a Morgana Autocreaser. It’s the older version without a screen (has the red led display for the measurements etc).
I tried to do an A4 half fold today with the fold at 148.5mm. Every time, it folded at 145mm instead despite it being set to 148.5.
Is there any adjustments I can make to make it accurate or am I just stick with finding an alternative measurement til I get the fold in the correct place?
aparat
The length between the leading edge of the sheet and the 1st crease position can be
calibrated in the event of the machine creasing out of position.
Also the last crease closest to the back of the sheet can be adjusted relative to the front
edge of the sheet to compensate for the inaccuracy of manufacture of the input roller
diameters.
The first crease should be 50 mm (2.00 inch) from the lead edge (less than 1 revolution
of the infeed roller) & the last crease should be 370 mm (14.50 inch) from the lead edge.
These figures match with the test sheet available from the production department.
Adjust the 1st crease position as follows:-
• Turn On machine
• Hold down the Push Button 4 and flick the Set-up switch down – the display will
show ‘dEtr’ and a numeric value of between 90 & 121.
• Rotate the setting dial to change the value (turn clockwise to Increase), a higher
value will move the crease further from the lead edge (105 is a good starting point).
• Return setup switch to ‘Ready to accept value.
• Run machine and check crease position – repeat above procedure until accurate
crease position is achieved.
Adjust the Last crease position as follows:-
• Turn On machine
show ‘dEtr’, press push button 3 & the display will change to ‘Etch’ and a numeric
value of between -128 & +127.
value will move the crease further from the lead edge, (0 is a good starting point).
thg
Finally someone answering straightforward without wanting to sell anything ...
Well done aparat, thanks!
halmac
Amen. Thank you. We have the very machine and I have been content to run a sheet and adjust accordingly. Thanks!
sidneykidney
Excellent reply Aparat.
Since we're asking, I have the same problem on my Morgana Digifold Mk1 which also doesn't fold in the correct position. Would you be able to help with that one please.
aparat
no problem, glad to help guys.
sidneykidney - on digifold is more tricky.
Hold push button 4 down and press the set-up switch to its down position, the
display will show ‘tabr0’.
3. By turning the rotary switch you can now scroll through the menu of available
machine settings that can be changed
Set the crease positions
Etch - Adjusts the position of the last crease position relative to the sensor.
Detr - Adjusts 1st crease position relative to the sensor.
allso sent you a pm..
De-Inking
Avanti
Link To White Paper
