I'm hoping to find a comrade with:
1) an icColor (more correctly a power supply for one);
2) a multi-meter;
3) willingness to test each pin of (1) and respond with the voltages thereof.
I have an icColor (that I bought on the cheap) that has no power supply. I've acquired the cable end for it and believe the power supply is one in the family of Phihong PSU-30-120 offerings but there are about a half dozen within that family to choose from. It's pretty clear that it's one of the 12v items but most PSU-30-120s employ a standard "PC laptop-esque" slip connector whereas the icColor employs a KPPX-3P connector.
The KPPX-3P looks like this:
KPPX-3P Kycon | Mouser
It's possible that the icColor used one of these (two) off the shelf PSU-30-120s (see link below) but if I get the wrong one my unit will go poof (since the pins and voltage thereon vary quite dramatically).
PSA-30U-M, 17W Triple Output
Alternately, I can acquire one of the more PC-esque variants and replace the cable end with a KPPX-3P.
Regardless, I need to know the pin/voltage associations. If you can help drop a line here or poke me privately.
Thanks!
JR
2) a multi-meter;
Thanks!
JR
