I am trying to match a sample; situation -
A local shop has produced a letterhead on Bizhub 6501.
The rep for the end user has provided us pdf file. I have produced a sample on my Bizhub 5500.
The file uses a gradient, yellow which starts at 0,3,13,0. All my colors are spot on to the sample excepting the gradient. The rep thinks I should be able to, or needs me to match the lightest area of the yellow.
My equipment is calibrated to the sheet prior to the print. Comparing all the other elements of the job and knowing their level of work, I fully believe the the other shops 6501 was also calibrated (regularly).
On the sample to match, you can discernably see yellow in the end of the areas valued at 1, 2 & 3% yellow; magenta has long past faded to 0.
The physical area of the gradient is about 1.5 inches (bleeding & darkest at the head).
AA9 Seps Preview uses Simulation Profile U.S. Web Coated (SWOP) v2. (Is this the embedded profile or my working space?) If I change the profile to U.S. Sheetfed Coated v2 it does display more as desired, (AGFA Swop Standard really pronounces the yellow). I have not been able to get the Fiery RIP to accept what I choose in Acrobat's Advanced > Color Profile. (Color Handling is set to Acrobat Color Management)
Fiery RIP > Expert Color is set defaulted to CMYK > SWOP-Coated (EFI) > Full (Source GCR).
CMYK Profiles available do not include many options.
I'm typically happy to know I produce consitent/repeatable color. What I print this week will be consistant to what we produce next month, but...I expect that 3% yellow should never be visable (easily discernable) and that enhancement technologies and local default color handling inconsistancies are always going to be of issue...
The rep will be providing me native files. Adjusting the gradient will not pose a problem, but that does not seem the correct solution to repeatable color across independent plants.
Any insight on where I have lost my Acrobat Color Handling Profile?
