avantra 25 agfa imagesetter
Dieudos123
I have the on agfa imagesetter:when I advance the film over the cuter it display error 06.
I tried all instructions explaned in the user manuel about troubleshooting but there is no
result.Please I need help if anyone can help me.
Hello
Error 06 = jum in cylinders, try to unload and reload the film.
Check if the "punches" are lowered .
Hi a-pap
I tried to unload and reload the film many times but no result.How to check the position of the punches?If there is other resolution you can help me please.
Hi a-pap,
I tried to unload and reload the film many times but I have no result.How to check the position of the punches?If there is other resolution you
can help me.
Hi a-pap,
can help me.
Sorry about my previous post i am not sure if its jum in cylinder or if you are out of film. Check your input cassete.
I will try to help you as much as possible. (Its been 5 years since i last used an avantra 44)
There are more than 20 reasons to produce error 06 and you gonna spend a lot of time trying every "advanced user advice"... call service or freelancer to come and see the real source of problem to be fixed.
I agree there are a lot of possibilities to consider for error 06, Is your film takeup cassette full or damaged or not loading film properly, Are your nip rollers worn.
I'd just cut the film with the cutter and put an empty cassette in and try to advance film, or reverse film back off the drum.
Rod
