Hello,
Vlad,Farshad and STSTech.I thank you for your help.
Bit now the error changed!Today when I started the machine so that I can to do what Vlad
told me,it displayed error 01(carredge jam)and sometimes it displays error 17 after error 01.
Please what can cause that?
Thanks in advance.
HI,
STStech,there is no film in the drum it still display this error after finishing to boot.
I could not clear the original problem,I started the machine so that I can do as Vlad told me and
it started with these errors.any advice?
Hello,
Thanks in advance.
Vlad,Farshad and STSTech.I thank you for your help.Now I tried to clean the spinner encoder and it appears that
that cleared some errors(#1,#17). but now when I do advance and cut it doesn't cut it still waiting it displays
the processor timeout icon.Is it the cuter sensor problem?
When I changed the home sensor the error 01 finished but but error 17 came often again and after
I clean the spinner encoder it did not come,now the machine finish to boot and I load the film in the drum
without problem.The problem is when I trie to advance and cut.It still display the processor time out icon a log time.And if test the cuter with Avdiag it passes OK.
Please if possible have you any advice?
Thanks in advance.
