Backup Question
jminrod
We have 4 servers that are being backed up every so many seconds to a NAS Server. We have 2 TB of space to use for this service. Now most of our files are on our main prinergy server which is Raid 5 As that gets filled we needed to move some files so we purchased a raid 5 5TB external drive. The problem is that it is not 100% guaranteed back up (So I am told) if 2 drives where to go down at the same time we would loose everything (So I am told).
My question or issue is my company no longer wants to keep purchasing the service for old jobs which is why we purchased the external drive so lets say in 1 year we used 1TB then those jobs continually get moved all through the next year, to the external, to make room for new incoming jobs.
We need to back up or mirror the 5TB External drive.
I am looking for the best way to go about this.
I am currently looking into Time Machine from apple but not sure if this will make it a 100% fool proof backed up system
Any help or suggestions would be greatly appreciated. Thanks Jim
Joe
While it's true that if 2 drives die at the same time you will lose everything, the odds are in your favor that it probably won't happen. You could set it up as 2 separate RAID 5 arrays and your odds would go up even more. What are the odds of 4 drives failing simultaneously? But it can happen, ie...fire, flood, tornado, hurricane, meteorite. So you can keep one of the RAID 5 arrays offsite to guard against that. It's just a matter of playing the odds and just how safe do you really need to keep the data?
jminrod
Thanks Joe, Is this something I would have to copy twice or is there an easier way of taking care of this?
Do I just purchase another External drive and make a copy to each?
Can I set them up to mirror each other?
Do you know if Time Machine (Mac Software) would take care of this?
pcmodem
Registered Users
Do you keep all old jobs live on your system? IE: you ran a job 3 years ago and it is still on your system.
jminrod
In a sense yes. We can only keep so many live jobs on our working server. All of our live job reside there. As that starts getting filled we move the jobs to the external. Then If the job comes back for a reprint we copy the job back to the working server and rename it with a new job number. We use the external alot more for referencing old jobs with out copying but to make a job live it needs to go back to the working server
Joe
If you are using the Prinergy Disk Archiving solution then yes it can do it automatically. Just set it to archive to the 2 different locations.
I don't think you can set it up to mirror each other but I'm not 100% sure on this.
Also I'm not sure if you can select multiple backup locations in Time Machine to backup to.
jminrod
unfortunately we don't have the archive feature we are only using Prinergy evo and not Prinergy Connect.
pcmodem
Registered Users
Anytime you have moving parts or heat. You have the potential for failure. We decided long ago to archive all of our old jobs onto CD (Back then), DVD (currently), and possibly BlueRay in the future. Granted it takes time to burn the disks and to retrieve them as well. But we know that not all of the jobs are going to be reprints and would just take up space on a Hard Drive.
When we burn DVD's we make 2 copies. One for production use and one for archiving off site for disaster purposes. If a production disk is gets damaged, we make a copy from the off site back disk.
mattbeals
You'd want to look to RAID6 and away from RAID5.
Configuring a RAID array isn't exactly the easiest thing to do. You may want to look to a SAN based on NAS devices from NetApp. These devices let you add storage as needed and help you schedule staging your data. There are a lot of ways to handle it. If you thing 5TB is all your ever going to need you can always mirror the RAID5 onto another RAID5. Do you really need to keep all of that as live data? Why not move it off to tape like LTO3/LTO4 and keep a copy at Iron Mountain? Heck, set up a service with Amazon's S3 service. Let them worry about data integrity. That's the easiest way of doing it, but it's going to require a big phat pipe going up to Amazon.
otherthoughts
No offense intended here Matt, just in search of greater clarity;)
More links - It's been a while since I retired, but the last I knew Storage Area Networks (SANs) were not based on Network-Attached Storage(NAS) devices. SANs and NASs were competing technologies with significant differences.
I've no doubts that there have been many advances in these areas of technology since I retired, so I may be confusing things here? If I am, please forgive my intrusion, if not, please clarify for us:rolleyes:
Best Regards and great comments by all!
OT
jonteo
We make a distinction between live jobs (currently in production) and completed jobs.
The live jobs reside on the production server (RAID5) and gets backed-up nightly to tapes and weekly to a NAS (RAID5). The NAS is further mirrored onto an external drive.
Completed jobs are taken off the production server and kept near-line on another NAS and again, mirrored. The files are then archived onto tapes which are taken off-line for long term storage.
All the backups and archives are driven by Retrospect running on a dedicate backup server.
To answer your question about the best way to mirror the 5TB drive:
The cheapest and easiest way is to mirror to another external drive. I would have a look at Carbon Copy Cloner. With drives so cheap these days, it makes sense to get at least a couple and rotate them to take one of them off-site at any one time. Costs for your solution go up as you increase flexibility, automation and redundancy.
smartsoft cover
