We've tested this and have found very little difference. You will see some benefit from applying normal AQ to the sheet first. For example if you're doing a spot soft touch, seal the whole sheet with gloss first and then apply the soft touch. Also, soft touch takes a long time to set up. You'll feel a difference days later.
