Brisque Impose Marks
HiTech_Monkeyboy
OK all you Brisque dinosaurs, here's a question for you. We are using Brisque impose with Preps imposition. Color bars are added in Preps. We are using a cut back curve when outputting plates. Is there any way to keep the curve from changing the screen patches on the color bar? Any help is appreciated.
Thanks,
Monkey
Re: Brisque Impose Marks
Check this, from the brisque client go to Edit/Preferences/Plate Expose and make sure the Apply ToneRep to ColorBar box is
not checked.
Thats assuming you are using a ToneRep curve and not an Excruve.
Mark
Edited by: Mark_S on Jan 10, 2008 12:21 PM
Why would you not want your curve applied to the color bars? How can you check TVI and gray balance (if you are using gray balance) if your color bars aren't output the same way your pages are?
