Re: colormunki
>Is it possible to use this device to measure dot gain like a regular densitometer.
I doubt it (and by that I mean "no", but I don't work for Xrite). It might be possible that you could extract the spectral data and calculate density and TVI in say Excel, but I don't know. You could calculate density/dotgain from the Lab values, but they don't always match values gleaned from spectral, and again, its a manual process.
For the functionality you're looking for, you might want either a separate instrument geared toward process control, or say and i1 Pro spectro, which is more readily supported by third party software companies that can get you the data you need. BabelColor CT&A Spectral Tools for example, you can get density and dotgain info quite readily.
