Going down the route or an Apple computer would be my dream and actually is our long term goal as a business. At present though we are too far embedded into the Windows eco system and have too much software that is ‘Windows Only’.I come from a background of building PCs at home, but using Macs for creative work. My former employer used to buy the prebuilt mIcrocenter brand pcs. Without exception, the power supply would fail within 6 months, and I would replace it with a good one (not a cheap one). Repeat for many other components.. My current employer normally buys Dell…same thing, except even worse because the ones we buy use a weird proprietary size power supply, motherboard, etc…
I think if you’re going with a PC, a lot of the prebuilt PCs are built to a price, you’re better off spending the money on building something if you select good components.
When I needed a new computer at work, parts had become too hard to get and were 3x what they used to cost. It was cheaper for me to get a loaded m1 Mac mini than to build a good PC, so that’s what I proposed instead. No regrets. Of course that’s another prebuilt proprietary system, but I’ve always had good luck with Apple hardware reliability…I have multiple 10+ year old macs that are still running smooth.
Yes the GPU issue was a snag for me as well. A mediocre GPU was very overpriced and hard to find a happy medium, and I wasn’t going to recommend we buy some $1600 gamer video card either.Going down the route or an Apple computer would be my dream and actually is our long term goal as a business. At present though we are too far embedded into the Windows eco system and have too much software that is ‘Windows Only’.
All our current PC’s are Dell Optiplex (either 7040, 7050 or 7080’s) and we’ve genuinely not had an issue. We have some old Optiplex’s (3020’s) that if they go to sleep you have to reboot the pc to wake it up but that’s one of the ones being replaced.
The main issue we have is we often use a particular photoshop file that is about 1GB in size. The computers really struggle with it and I’ve heard that a 4GB+ GPU is ideally needed for photoshop. So, I’m either going to build some new custom PC’s or go down the route of the Dell Precisions.
The main advantage to the Dell at the moment is that GPU’s are insanely expensive, so where a GPU might cost me £400+ on it’s own, I can get the whole Dell system with a Quadro P2200 for £1150.
As the "IT guy" at work I used to build all the PCs myself, but in the last few years have been replacing as needed with Dell machines, mainly because we then have a single point of contact for support, drivers etc.Just curious how many of you on here have custom built PC’s vs pre-built from the likes of Dell and HP.
Looking at replacing a couple of PC’s and having a hard time decided between some Dell Precision’s and some Intel or Ryzen systems.
Thanks for your view.Off the shelf computers these days seem to come in two forms: inadequate home/office units, or those built for gaming, which is often expensive and visually impressive, but isn't always ideal for graphic design applications. A semi-custom PC will give the best performance for your money. A Ryzen 5 5600 will give excellent bang for your buck, with a top Photoshop benchmark that beats Intel and even their own higher priced multicore processors. Don't go any less than 32GB of fast RAM. A GTX 1660 graphics card will be plenty if you don't do video. Finally, a solid state drive is a must. Go with a M.2 NVME type SSD for the fastest possible performance. 1T is a good price point. A good builder will be sure you have a properly sized power supply and cooling. You can customize a liquid cooled Alienware with these specs for under $1700 at Dell. Though it is a gaming computer, Alienware tends to focus on performance over visual effects that are a waste of money.
ADD... If you don't need 10 bit color for matching on your monitor, my monitor is a 43" 4K TV. Extremely nice when working with multiple applications or working with a 60 column excel file.
Seems like a good deal. The problem I have found with PowerSpec is cutting corners on the memory. High latency, sub-prime memory. That can make a perfectly good computer a dog.Happened across this. Seems a decent deal:
PowerSpec G509 Gaming PC; AMD Ryzen 5 5600X 3.7GHz Processor; NVIDIA RTX 3060 12GB GDDR6; 16GB DDR4-2666 RAM; 500GB SSD; - Micro Center
Get it now! The PowerSpec G509 desktop computer is a powerful gaming machine featuring the AMD Ryzen 5 5600X unlocked processor, an ASUS B550M-A/AC system board powered by a 650W PSU, 16GB DDR4 2666 RAM, a 500GB NVMe SSD, and a NVIDIA GeForce RTX 3060 12GB graphics card to provide an incredible...www.microcenter.com
Just remember that the more cores, the less speed per core. Adobe doesn't take much advantage of cores, so it does't really benefit, which is one reason why the Ryzen 5 outperforms almost every other processor on Photoshop benchmarks.I just thought I'd post an update on my decision...
I declined the quote for the Dell Precision this morning and have decided to build 2 custom pc's instead.
My reasoning in the end came down to the fact that Dell (and other manufacturers) cut corners in places that I may not even be aware of. The reviews I've seen suggest that the Dell Precisions get incredibly hot and start to thermal throttle, and the power supplies are often proprietary making it difficult to upgrade in the future. I'm not sure about the Precision line up but I know the current home PC's don't even have a 24 pin motherboard connector. Top that with the fact the Xeon CPU was only 6 core vs 8 cores in the i7, it just didn't make sense to get the Xeon.
In the end, I opted for buying two Quadro RTX 4000's off eBay for £525 each) and will build the two PC's around those. I figuredthat I'll be able to do the full build foraround £1300 with a much better GPU than the Dell would have had.
Xeon processors support error checking and correcting memory so are more stable and less prone to data corruption due to memory errors, whereas i7 processors do not.I just thought I'd post an update on my decision...
Unfortunately I’m in the U.K. so can’t access that linkHappened across this. Seems a decent deal:
The systems I was looking at used lower end Xeons and I don’t have the budget for a higher end one unfortunately. They also had standard DDR4 memory and not ECC ram.Xeon processors support error checking and correcting memory so are more stable and less prone to data corruption due to memory errors, whereas i7 processors do not.
The current i7 range of processors (i7 - 3770k for example) are limited to 2 memory channels, and a maximum memory bandwidth of 25.6GB. However Xeon processors reach far beyond this with 4 memory channels in total and subsequently an excellent 51.2GB memory bandwidth so Xeon processors can move significantly more data to cache.
Intel i7 processors have a maximum of 8mb of cache (only 6mb in i5 processors for example) whereas Xeon processors have much larger on-board cache than i7's and start at 10mb – 30mb for high end Xeon processors.
Xeon processors support multi socket configurations (an HP 820 CAD workstation for example supports up to 16 processing cores)
I have a Dell Precision workstation with an Nvidia Quadra as my home computer and it is a beast, no issues with overheating.
I purchased a Dell via Costco. Their package offered a largee capacity SSD at a lower price the direct. But be warned, I recently contacted Dell concerning the need for a copy of Windows 10. Since the warranty had expired they refused to offer assistance unless I paid for an extended warranty. They leave you hanging. In the future I think I will return to building my own.Just curious how many of you on here have custom built PC’s vs pre-built from the likes of Dell and HP.
