EPS --- CMYK file prints color differently than file
auchprinting
Color is correct PMS 350 CYMK on digital Proof. Lighter color on press. The press prints sharper, but the dot is smaller. The file size is 100KB. Is that file high enough resolution.
gig0
If the proofs don't match the press then it sounds like you need a color expert to adjust your curves/profile.
auchprinting
The question is about the density of the file. Is 100KB a large enough file to print from on press? A color Proof from the copier is OK. When I go to press, I get a smaller sharper dot. Since the dot is smaller, the color printed on press is lighter.
buckeye
The density (resolution) of a file, as you put it, has absolutely nothing to do with color match. The fact that your proof and press sheet do not match, has everything to do with profiling possibly both your proofer AND press to some sort of printing standard.
Thanks,
Erik
Alith7
If it's a vector file and not a raster file, it could easily be only 100kb. everyone else has the right of it, if your proofs don't match you press, you have a COMPLETELY different issue. the first step would be to figure out which is wrong/right, and go from there. if it's a PMS to CMYK conversion, how does you print look to Pantone's Color Bridge swatch?
Print In the Eye of the Buyer
Canon White Paper
FIVE PART SERIES:
FREE DOWNLOADS
Print In the
Eye of the Buyer
Download Free White
Papers Here
