Epson 9800 "Blank Page"
bweb
Hello, I have an Epson 9800 and I have a problem. I was doing a nozzle check because my yellow was missing segments. After two nozzle checks it started to print “blank” pages. I followed the procedures by doing a power clean. Afterwards it wouldn’t print anything. When I check the ink tubes there appears to be air bubbles in the light magenta and light light black tubes. When I perform the nozzle checks, the air bubbles stay where they are as if the ink is not being pressurized. What should I do next?
Unfortunately, you'll probably need to contact service. My guess would be that the pump/cap assembly (which sits under the print head carriage when it's in home position) is misaligned or is worn out which can create vacuum leaks when cleaning the printheads.
It's also possible that the light magenta and light light black ink lines themselves could have a leak in them.
pd
