error "Buffer not null" Navigator 6 + Agfa Accuset 1000plus
007br
Hi everybody,
"Buffer not null"
does anybody know why i recieve this message on navigator 6 when i tried do 'enable' the print to imagesetter(Agfa Accuset 1000plus)?
how can i proceed?
Thanks, i discovered this site today
Att,
Adriano Farias
Does it happen on every job? If so, you may want to try clearing out your queues and starting with an uncalibrated target. Go to the OUTPUT - PRINT CALIBRATION window and select your page setup. Click PRINT UNCALIBRATED TARGET. This should print a test target into the active queue. Once this is done try to output. Does the problem occur on output?
It could be an interface card or plugin message. Would need more information to verify.
