We have recently upgraded to 27" iMacs using 10.6.6. I have noticed that if I put a folder into the fonts folder for of Indesign CS3,CS4 or CS5 and then want to move it out of that folder to the desktop it copies the folder. (This happens with every folder in the applications folder) If I put it into the trash it moves the folder/file to the trash. Why is it copying the folder/files rather than moving, we have other intel macs using the same system software and they are not reacting the same way? The The indesign folders and font folders are set up as read & write for all the users? The Applications folder is set up for the system, admin to be read & write and everyone is set up as read only, if I change the everyone to read & write the results do not change.
I should mention that our mac user account (this is a general account that is local), works as it should. The smb account that I am logging into using my AD credentials is copying folders, rather than moving them. I assume it has something to do with the home folder on the server rather than local. Can anyone tell me what setting needs to be changed to fix this?
