Gallus RCS 330 and CTP
Gaz
Hi. Trying to find info on a suitable CTP device to supply plates for a Gallus RCS 330. Having problems finding a CTP device that has
in line punching that can punch on the narrow edge of the plate which is 362mm. Any input please.
Re: Gallus RCS 330 and CTP
Have you tried to get you plate supplier to pre-punch them to work on any CTP system.
Hi Jay.
Thanks for your input. Have spoken to plate supplier about pre-punch but not possible due to quantities, etc, etc.
Hello, Gaz,
I do not have exact plate dimension for RCS 330 available, but, I believe, Heidelberg Suprasetter A74 might be worth of look:
HxW from 240 x 240 millimeters (9.45 x 9.45 inches) to 670 x 750 millimeters (26.38 x 29.53 inches).
AFAIK, there is standard punch available to be mounted on width of 220mm, but there is possibility to order customer specific punch (might take longer to be produced).
Anyway, have a word with your local HD representative.
Regards, Janez
Hi Janz.
Thanks for your input. Will look into it.
Regards
Gaz.
