moundcitynews
We are running an 8 unit Goss Community with a Goss SC folder.
Config. =
4 mono units on the left side of the folder and a Goss UOP three color unit with 3 other mono units on the right side. All units are on the ground.
We have 2 web tensioners - one for the UOP and one at the very end of the "left" (Units 1-4) side of the press that we run through before hitting the cyan (unit 1)
The paper roll starts under unit 2 and then travels under unit 1, then through the tensioner, then through the 4 mono units to the folder.
No pull in problems at all with any of the other webs, just when we add the bottom web color from the "left side" of the press.
The color registration on the UOP is nearly perfect, but when we add the "left" side of the press printing 4-color through the 4 mono units (which is the very bottom web) we get color registration/pull in/paper stretch problems with the bottom web.
Normally print 3 to 4 webs total.
Pull-in problem worsens when running more webs, but paper stretch/registration problems always occur when printing from the "left side" of the press which is always 4-color. (even when running only one web through that end)
Any thoughts?
Config. =
Any thoughts?
