Hi guys,
Im new to the forums and wondering if you can help me. I design posters, invitations etc and am currently doing a wedding. I need to do 100 saddle stitched ceremony booklets.
I wasnt planning on purchasing one of those booklet collators or anything like that. I was assuming with my scoring machine and a long arm stapler i could sort it all out.
But then i got to wondering a bit.
The booklet cover will be printed from 300gsm/140lb sra3 or a3+ as you might call it. 2 covers per sheet, trimmed to size.
The inside pages i was assuming would just be standard copy paper....
But when it folds, will i have a creep problem? is it an issue? There are not usually many pages in this type of booklet. Is there a better method? should i print the inside pages on sra3 size also and then score/staple and trim the whole lot to size?
I was thinking it could be a little tricky lining it all up if using untrimmed sheets to make the booklet.
Im a little confused in what order this should all happen. Any advice would be awesome.
