Help_Can't get disk out
rande
Power PC G5 10.4.11
I tried disk utilities.
Took it apart; tried pushing the disk unload manually.
Tried a paper clip in the little hole. That use to work.
Nothing. It just made some bad noises and keeps mounting my drive.
I had the same problem with a Intel iMac.
What I had to do was pull off the white cover, then I had to lay the Mac down and keep hitting the eject button on the keyboard while I was trying to hold the flap down in the drive that keeps coming up and someone else was using a dental pick on the non-emulsion side of the cd and was fishing for the whole in the center. After a few attempts we were able to pull it out. The main thing is it probably keeps hanging up on the little metal piece that comes up.
There is a video on You Tube.
YouTube - Eject a stuck disc from an intel iMac
