How can I do, make a PDF like PLATO
pitor
Sorry but I havent a license for plato, and Im trying to do one PDF without lines and images, Anybody knows how to do this files. on backstage or Packedge. I want to do my step and repet Manual on Packedge, and generate a PDF for ONLY visualitation. PLEASE.
place the grs file as "external file" and repeat them as you want with the repeat tool (alt+enter to call it).
You can use the smartmarks as you use them in Plato, even you can use a set of smartmarks (we usem them for diferents clients, each client a different set). So, you put all the marks with the smartmarks and then fit the margins to the total area and export it as a pdf file..
hope it helps, tell me if you need more directions,
cheers
Marcelo
Hi Marcelo, still me
Hi Marcelo, Maybe my Question is not right. My question is about to create a PDF for previsualization, like a PLATO, Im working now manually my repeats, but I know the function of ticket for step and repeat on backstage, and the file result is a plato file, when I open that file appears the files embeded and like a image from original, Do you know How to create a PDF file as a image from the original? and What options I will ve to take?
Ok, i think i have got it, you want to get a PDF (from a Plato file) delivered from Backstage,
I guess that you have Plato license, otherwise I dont think you could make it, and I guess you also have the special ticket that allows you to make step and repeat within Backstage..
If you have all these things I dont see what the problem could be, but listen, tomorrow at work I am going to play around a bit with it and tell you what it can be. If I can help you in any way.
cheers, Marcelo
