How to create print driver 'HOLD' for Command Workstation ?
ruthndul
Long story short, I reinstalled the print driver for CWS
The new print driver is a straight print
How to create a 'HOLD' print driver for CWS
Mac OS X 10.7
Thank you
Mac OS X 10.7
Thank you
I just did this last Wednesday. On a Mac running 10.7 as well! If I remember correctly, installing the Hold drive is the same as the Print driver only at some point during the installation process there is a drop-down menu that allows you to select which one. Of course, it defaults to Print. If you can't find it, I'll go through the steps again tomorrow so I can pinpoint it.
Install it as a IP printer and set the queue name to "hold".
IP Printer.
Queue has no option
I tried to type in manually 'hold'
it shows error afterwards
queue left blank shows error too
If you look in Command Workstation under virtual printers, what does it show? If it shows a hold, type in the name exactly as it appears there.
It shows 'Hold', 'Print', and 'Direct'
where should I type in the name ?
I tried to manually typed in DC700 Hold in the 'name' field, but it prints directly, seems to be just a name
This is how I do it for mine:
I think it is a lot easier if you know the ip address of the machine. If you have command workstation running, it will show what the ip address is for your machine:
very strange. Under "Queue" can you put "Hold" instead of DP700 hold? If that does not work I am not sure. Do you have a service contract with Xerox? Maybe they can walk you through it and figure out what is going on here.
"Hold" only instead of "DP700 Hold" WORKS !
Thanks WONDERING for your patient and kind help !
Yes ! Problem solved !
