How to find a professional forum for paper related question‘s
Buntpapier
Hi!
I am searching for a forum like this but regarding paper technology.
I have to build illustrative model of a sheet of paper in relation of 1:100. A 100g paper will get a 10 mm thickness. To do this I need more information’s about the fibers. For example length, diameter, amount of fibers in relation to the paper volume. Are fibers more like a pipe and if yes which wall sickness do fibers have.
The forum language does not matter. I just need a good forum.
Buntpapier
Hi!
Buntpapier
The place to start is TAPPI:TAPPI
Buntpapier
Hi Gordo!
Thanks for the hint. At the end it wasn’t TAPPI, it was another paper freak. But anyway the direction was perfect.
Buntpapier
traviscalder
Hi Buntpapier
I am having some problems with a Polar Mohr 76 SD-P machine, I have seen from some old forums that you are very helpful and knowledgeable on this machine. Are you still active on the Print Planet forum? I will explain full story...
thanks
Travis
traviscalder
Hi traviscalder!
I will try to help. What is the problem.
Best regards
Buntpapier
Hi Buntpapier
You helped me before on a troublesome 76SDP, now when I switch it on, it just flashes the ( = ) icon on the display. No keys seem to do anything, the machine seems to lock out and not allow anything.
No other error codes, just ( = ) flashing.
Do you have any ideas please...??
Travis
