Re: Image problems with C6500
Gradients that fade out to zero are not easy on any toner based engine, including the C6500. Banding and striping are inherent. Toner does not blend out well like ink and you will see bands in the gradients as they fade out of solid. This is especially true with colors like green, purple, brown and orange. Blue is tough too, you will typically see Magenta stripes in the <30% range of the gradient. This is a problem that will be very hard to service, you might consider changing your design, it may prove to be less frustrating in the long run. Make sure your machine and Creo are up to date on firmware, service packs, and patches. Calibrate using the densitometer on the media you are priniting on, and cross your fingers.
Edited by: Chad Gutierrez on Feb 16, 2008 2:15 AM
