Indigo 1050 color calibration problems
Are you sure that the density in the tank, or the board in the ink tank is okay?
If there isn't enough pigment in the tank you won't get it higher..then what 's in the tank.
Or it might be that the inline is "broken" that it doesn't see the yellow channel...I thought, but it is some time ago that you're able to some factory setting or a firmware upgrade. (but I'm sure on the last one...)
