Inkjetters
pabney
I currently have two inkjet systems for addressing my envelopes. One VidioJet 4320 and one MCS Imager. Both of these are currently running old software circa 2003 or so on Windows XP boxes. I am may need to replace the computers soon because of some hardware issues. Thought I would ask the brain trust if I should replace the hardware and keep the Windows XP, or are there upgraded software systems for these machines?
MailGuru
Hey Pabney, we're in pretty much the same boat. Running (2) Kirk-Rudy W-Inkjets. The machines run beautifully, but, the firmware on the printers won't run on anything higher than Windows XP. The interfacing software is called "W'Inkmate, (circa 2000) and, it won't run on anything higher than XP also. We've had to change the boxes a couple of times due to hardware issues. We just keep a CD set of the XP operating system around to reload on the new boxes.
pabney
That's about what I figured. I was asked if there would be any benefit to try and upgrade the software, but it does everything we want it to do now, so I will get get a couple of new boxes and install XP.
MailGuru
I should interject here that the two boxes running the ink jets are specifically for those two printers only. We configured out network so those two computers have no internet access. There are no security updates on XP and Microsoft discontinued support on XP last year, so, if someone is able to get to the internet on those boxes, it poses a significant security threat.
pabney
Thanks, we already have them set up that way. As well as the only other box in the company that has to run XP for old software.
I appreciate the concern.
kansasquaker
Be really careful with the MCS. Unless it's a newer one, they use firewire to to connect the print controller to the PC. That can be a real issue if you try to upgrade past windows XP. Not to mention software compatibility. I always try to preserve the original system on PCs like that. The software/hardware combination was built with whatever OS in mind and often doesn't port well to different configurations. Of course you have security concerns with that approach . . .
pabney
Thanks for the tip. I had not gotten behind the machine as of yet, but I did ASSUME it would be a serial connection. I will be sure to check it out before I do anything.
PricelineNegotiator
Why don't these manufacturers step to a standard like USB? It's going to be around for a while and the bandwidth throughput is way better than serial for crying out loud.
Puch
Don't upgrade. You can get server class hardware el cheapo to run the available (and satisfactory) software forever. If your IT dept. is up to their their jobs regarding the company firewall, there's no need to worry about the Win XP, too.
What About Profitability?
Canon
What about Profitability?
Offset yields new advantages
Read All About It
