jpfulton248
I just got a sample pack of Genie laser plates for testing with our Laserjet 5100 and our Itek 975pfa. I have my print settings pretty well worked out. Printing from Acrobat Pro at 1200 dpi and 106lpi with media setting on Cardstock. Not brand new, but OEM toner being used. 2 problems I'm having:
1. More often than not when I produce a plate, there are a couple places on the plate where I see streaks. Usually it's in a location where there is a solid or a dark gray scale... there is a one inch long streak starting inside the solid and dragging outside of it. Almost like a roller is dragging the toner out of the solid before it has time to fuse. Regardless of what the details of the cause are, there are definitely streaks on some of the plates in a couple spots... steaks are about an inch long and again -- only after solids.
2. Our pressman hung one of the plates and tried running it. As far as I know he didn't do any prep to the plate and hung it right on the press. He used the existing fountain solution that he uses with our standard plates. The images coming off the press were very dark and all of them had a strange "outer glow" or drop shadow effect...
We are done testing for now until we have another offset job coming through but in the meantime -- anybody have any ideas?
Thanks in advance
Pete
Thanks in advance
Pete
