Long rip time, complex PDF.
padrao
Hi i need one solution for the PDF`s with very complex vector´s inside .
The PDF is small format, but this will mounted on one sheet size 1000x700, and after send this job to metadimension it take 2 to 3 hours to output the job on CTP .
My question is what can be done on PDF or application to make it more easy , without convert the vector in image .
All the experts are wellcome . . .
Here is the link for the file .
4shared.com - online file sharing and storage - download PDF file.zip
All the Best
Padrao
This is a question that the people of metadimension should be able to help you with.
Just for fun I downloaded the file and ripped it in Navigator 8.1. It only took a minute or less to process but I was ripping it at a very low line screen. I have found that this upgrade really improves rip performance for complex PDFs and files that contain transparencies. What rip were you using and what is your final line screen...just out of curiosity. Not sure if that helped with your concern or not...
Down loaded and Ripped
I Ripped and Trapped your file on our Meta Rip 7.5.1 - Time 1 minute 10 seconds
Rip time
Rip time
The Rip is Metadimension 7.5 connected to PrePress Manager 4.5 .
To rip one file, there is no problem, but when outputed from one Layout,from signastation on size for sm102, the case is diferent . Try to mount for paper size, 1000mmx700mm .
All the Best
Padrao
All the Best
Padrao
MetaDimension 7.5.1 and PPM 4.5.2 here, RIP time 21 minutes, 36 seconds.
Spool time: over 40 minutes. Combined gives around 1 hour for a 1000x700 form filled with these.
Regards,
toronar
Same software as before, but this time I ripped the form with CPSI instead of the APPE.
As usual, CPSI blows APPE out of the water in speed: 3 minutes 19 seconds rip time, 3 minutes spool time for a grand total of around 6 and a half minutes for the 1000x700 form filled with the PDF.
I would say Adobe has a lot to optimize in its APPE :)
