Mac OS 10.6.3 vs Prinergy Evo 3.2.6
New to the sight.
I cannot get Prinergy Evo (3.2.6) to work with OS 10.6.3. I have read that re-installing Java 1.5 will solve this issue. Does any have any insight?
Thanks in advance
Ddog
Java downgrade
Java downgrade
The method in the link below worked fine for me with Mac OS 10.6 and Prinergy Direct. Be sure not to not install any Java updates when they are detected via the Software Updater. Otherwise you'll have to go through the procedure again.
OS X 10.6 Snow Leopard - OneSwarm Wiki
Tom
Thanks Tom.
I tried the method listed but Prinergy will still not accept my files. I am able to go to a different Mac with an older OS and put the exact same pdf through the refine folder with no problem. When I try from the Snow Leopard Mac I get this error message. "Some of the files could not be opened. They may be locked or you may not have sufficient access privileges."
Thanks again.
pajdzn
Snow Leopard confilt with Prinerg EVO 3.2.6
I have the same problem and have contacted Kodak. They said EVO 3.2.6 is not compatible with OSX 10.6.3 and the only solution is to upgrade, aside from using and older system to run files through the RIP.
We had to upgrade to Snow Leopard for CS5 files. So for now I have to split my work between 2 stations, one to do the work and one to use the RIP functions, until I can get the powers that be to spend the $25,000+ for the upgrade. I suspect I may be retired by then.
SpNac
You have 2 methods for mount Hotfolders and Jobdata by the network from Mac.
Try press (Apple-Key)+K from Finder.
In the "Connect to the server" Window Put:
afp://"your Prinergy Evo IP" and connect with User:Administrator and Pass:"administrator password of Prinergy"
Try work in this way.
If it´s fail then try:
Unmount Hotfolders or Jobdata mounted previously.
Press (Apple-Key)+K from Finder.
smb://"your Prinergy Evo IP" and connect with User:Administrator and Pass:"administrator password of Prinergy"
It should work of someone of two ways.
It is verified in a Prinergy Evo version 3.1.
Nacho
SpNac
Verify that you are not connecting as guest to Prinergy. It´s very important since Snow Leopard connects, by default, as guest. Connect as user:Administrator and pass:"administrator password of Prinergy" by afp or smb protocol with Prinergy IP. I believe that you should update to improve functions in Prinergy but not to improve connectivity.
Nacho
afp:// Works!!
afp:// Works!!
Thanks for the tip - connecting to JobData & PgyEvoConfig server with afp:// worked for us on new Mac OSX 10.6
