Magnus/Lotem 400 Error while loading plate
geldsetzer
Hi there,
I receive the following error while loading a plate:
The task Load From Drum Entry to Drum Loading System failed.
The task Loading Stopper Valve On Switch failed.
Operation not successful. Error On Loading Stopper Valve Valve/Solenoid HP detector : No change/No Valid state of Detector in ON Operation
The log file shows that the stopper valve switches off successfully:
Busy Loading Stopper Valve 0
Task-Log Loading Stopper Valve Off Switch Complete - Status:Success , RetValue:0, TimeSpan:0sec
But later switching on fails:
Task-Log Loading Stopper Valve On Switch Start
Busy Loading Stopper Valve 1
Exception CLocal3Valve ID = 8611 Operation not successful. Error On Loading Stopper Valve Valve/Solenoid HP detector : No change/No Valid state of Detector in ON Operation
Error Loading Stopper Valve 1
Task-Log Loading Stopper Valve On Switch Complete - Status:Fail , RetValue:0, TimeSpan:11sec
Do you know which part causes the error? Is there a sensor I can check?
Regards,
Thorsten
Thorsen
First thing to check is the air pressure. must be around 75psi or 6 bars.
Was it the first plate of the day ?
Hi printmono,
air pressure is fine and no, it happend after some plates already done. Now the error happens every time.
Regards,
Thorsten
