Man Roland scanning densitometers
JRom
We are a Man Roland shop and when I go out and do press proofs
I am using a XRite 528 for checking densities, our presses are set up for status E and I would like to change
them to status T. Is this possible from the console and or printlink ?
John R
Re: Man Roland scanning densitometers
I don't think you can, John, but you can switch your 528 to read Status E. That way you and the pressmen are playing in the same ballpark.
rich
Thanks Rich.....Guess I just have to read the manual on the 528 to change it :)
It was really the press room that was asking, its not a big deal....they just have to trust me !
I'm going to leave it as is.....Im a status T type of guy.
John
I'm afraid that the Status E readings on the Roland don't line up with Status E from a 528. It may be the Roland's polarization filter, I'm not sure, but the Roland readings will be quita a bit higher (About 2.0 on average) in all 4 colors.
Best approach is to get a sheet with proper densities according to the X-Rite then set the corresponding Roland readings as your targets.
Glenn Andrews
