Have just been looking up the msds sheets for both n-propyl alcohol and Isopropanol alcohol . It seems that N-propyl alcohol would be a safer option with its lower vapour pressure and evaporation rate, Is there a reason that printers don't use it more frequently in fount solutions rather then Isopropanol ?
With the figures below, it would seem that you could run n-propyl at say 6% versus Isopropanol at 3% and you would effectivley be emmitiing similar VOC levels,
I have only come across one fount that has n-propyl already premixed in it, But if you were to dose it yourself the possibility to cut VOC levels even further would be great.
Anyone using this stuff?
N-propyl alcohol
% Volatiles by volume @ 21C (70F):
100
Boiling Point:
97C (207F)
Melting Point:
-127C (-197F)
Vapor Density (Air=1):
2.07
Vapor Pressure (mm Hg):
21 @ 25C (77F)
Evaporation Rate (BuAc=1):
1.3
Isopropanol
100
Boiling Point:
82C (180F)
Melting Point:
-89C (-128F)
2.1
44 @ 25C (77F)
2.83
N-propyl alcohol
100
Boiling Point:
97C (207F)
Melting Point:
-127C (-197F)
2.07
21 @ 25C (77F)
1.3
Isopropanol
100
Boiling Point:
82C (180F)
Melting Point:
-89C (-128F)
2.1
44 @ 25C (77F)
2.83
