Need a Indesign PPD to work with windows XP, to rip in agfa accuset 1000
I have a Accuset 1000 plus which the rip is apogee and it runs by G4 Mac.
I usually make my post scrip file from indesign in pc with windows xp, and move the postscript file to mac by a flash drive and it was working for a long time.
but unfortunately My PC computer with widows Xp, has crashed and I had to re install the windows again, now I don't have the ppd any moor, when I installed the adobe ppd, that I got on adbi site, is not giving me the 2400 dpi and 150 line resolution, any moor even when I select it still out put film as a 1200 dpi, I think I don't have a right ppd, can anybody help me to get the right ppd for window xp.
Thanks for the reply,
how do I install it and would it work with indesign and windows xp?
the ppd that I have installed is outputting lower resolutions ( 1200 dpi ).
VladCanada
Everything described in RIP Manual (see installer CD).
PPDs generated by AGFASET gives you full ability to manage lots of params, including resolution/LPI combinations of AGFA Balanced Screening.
VladCanada
Just remember: RIP settings override Imagesetter params and settings.
(in case of Accuset connected to RIP - 1200 dpi is default param).
In your case you have to:
start AgfaSet,
generate EDF files,
choose correct EDF, change params you want and
mark checkbox SAVE AS DEFAULT!
That's the easiest way to manage RIP+Accuset combination than PPD usage.
start AgfaSet,
generate EDF files,
Thanks, I find some ppd's but I don't know how to install ppd in my PC,
I need to make a post script files to output film.
WharfRat
InDesign has a fine PostScript writer built into the application.
Just "print" and select "PostScript" as the printer and "Device Independent" as the ppd.
(or you could pick the Adobe pdf ppd)
MSD
MSD
I have already try that but my postcripts become 1200 dpi when it gets to agfa accuset 1000
MickRose
Xp ppd
Xp ppd
We use an Agfa 1000 imagesetter on a PC running XPSP2. The driver is created is created using the Adobe PS Driver software & the connection using PCMaclan (XPSP3 doesn't work for us, it must be SP2). It all works fine apart from the fact that everything is very old. If you need a PPD for the driver give me your email & I'll send it over
Mick
hello, good afternoon, greetings, I am new to the forum, I would like to know how I can find the software to rip the apogee pdf rip, I have an agfa accuset 800, thanks
