No view file in PowerLayout
Had this problem in 8.1 ver. 4, thought that the upgrade to PowerLayout 9 ver.2 was going to fix. No such luck.
Basically when you apply the graphics into the repetition layer of the layout. it does not create a view file. The file is there though because you can see the colors, ie. 5th colors, in the separations palette.. So inevitably the only way to see if your work is centered and bled the way you prefer, is to view the final plate file at the CTP front end.
Is anyone else having this problem and if so is there a solution?
