Output profile
jtan
Does anyone know how to convert ICC profile in CMYK or RGB to output profile? I tried to make ICC profile using Profilemaker but when I import it it goes to CMYK or RGB, but not to Output profile where I can use it... any ideas? Thanks.
Make sure you're selecting Import as.. Output profile?
probably not, maybe i miss something, because the version i'm using is Windows, i'll check it out again tomorrow back to our lab then will post update. thanks.
There's no conversion process. It's just a question of which folder you put the profile in. Depending on your version, you might have to import a profile first as a CMYK profile, and then move it into an output folder.
However, CWS won't let you put an RGB profile in the Output folder because driven by the RIP, the printer is a CMYK device.
Mike Adams
Correct Color
