Pitstop 9 Acrobat 9 - Moving Text on top and bottom too close to edge.
CruzinCooler
Hello,
I was wondering if there is a way to create an action just to move text that is about an 1/8" from the top and bottom (and sides) of pages to 1/4" from the sides and top & bottom? I am only able to move the text all one way or the other. Meaning all text to the left an 1'8" and either all down or all up an 1/8".
Thanks for any input.
CruzinCooler
CruzinCooler
Have you tried "select objects inside or outside region"?
Yes Caio but i had to set up a couple actions to achieve both up and down movements. I guess i could set up an action to do both but I am unsure how to get it to do both at the same time.
Thank you for your response.
CruzinCooler
Thanks Caio,
I found out all I had to do was create a profile from the "PDF Profile Panel" and added the 4 actions that performed the separate tasks. It ran like a charm. Thank you for your support.
CruzinCooler
Thanks DCurry,
As I posted in another reply I found out all I had to do was create a profile and add the 4 actions that performed the separate tasks.
Thanks again.
What About Profitability?
Canon
What about Profitability?
Offset yields new advantages
Read All About It
