PitStop Pro compatibility with Acrobat DC
abc
Hi all
You have probably seen that the latest Acrobat version, Adobe Acrobat DC is now available.
Just a note if you are running on a Macintosh then you will need PitStop 12 update 3 or PitStop 13 (when released) to work with Acrobat DC.
We already did a lot of the work preparing for this new Acrobat with the 12 update 3 Version which was released in October last year.
On Macintosh previous versions of PitStop will not been seen when installed as Acrobat DC is 64-bit now and those older PitStop versions are 32-bit.
Acrobat DC on Windows is still 32-bit so will be ok
Vernon Roberts
Thanks for the information. Would you happen to know if you can safely install DC from the CC panel, without affecting your existing Acrobat Pro XI installs and PitStop configs? or will it overwrite XI.
abc
From what I have read on various forums it replaces the Acrobat XI installation.
https://forums.adobe.com/message/7413513#7413513
For PitStop on Macintosh before you upgrade, what you can do is go into the applications folder to Acrobat XI and right click on the 'Adobe Acrobat Pro' icon for 'show package contents'
That will open a folder structure, if you go to 'plugins' you will see an 'Enfocus' folder. If you copy that to your desktop and then do the Acrobat upgrade, you then repeat the process backwards and put it back in the same place in Acrobat DC.
That gets around having to re-install PitStop again.
Vernon Roberts
Well that's just rude of them to replace your existing version. INDD, PS, AI always let you do different apps for each new release. Wow, the people on that forum should have done a little research before updating. I thought it was an update for INDD at first because they changed the color of the icon, lol.
leonardr
DO NOT put the plug-ins back inside the application package! This is NOT recommended behavior since Acrobat X and will cause problems such as the one you are seeing now. Acrobat X and later support an EXTERNAL plugin folder where they are safe across updates and upgrades. PLEASE use that folder instead.
leonardr
While it is true that the CC apps do this, Acrobat has NEVER supported multiple versions of the application installed at the same time. Yes, I am aware that customers do it - but we CANNOT and DO NOT support such a configuration. You are on your own - as evidenced by this expectation that we wouldn't replace your old version.
prepressdork
Hi Leonard,
What does Acrobat DC bring to the table for us in the printing industry?
Also, what is Adobe's plan for continued updates to CC apps? Will they continue to update the 2014 version or will there be a 2015, 2016, and so on version? If the latter, why?
Thank you,
pd
leonardr
Specific to the printing industry - the main item would be a completely rewritten, faster, more functional Preflight tool.
However, you also get all the other major features such as the improved (and VERY customizable) UI, eSignatures (which are great for things like custom proof signoff or just customer contracts), cool improvements such as the new Organize Pages feature, etc.
Joe
Yet still having Output Preview open and shift+clicking an object creates a new sticky note instead of adding to the current selection. Have you all lost your minds over at Adobe?
zoran
Writing was on the wall for a while, Adobe's priority is web and mobile, like the rest of Hi-tech industry.
They do not care much about printing and prepress anymore, I can't blame them.
I do appreciate faster Acrobat, as soon as our plugins gets updated, I will switch, too bad I can not keep old and new acrobat in parallel as usually.
FileJockey
If you temporarily move your XI out of the applications folder, then DC will not overwrite it when installing. Keep zipped versions of previous Acrobat/Pitstop installs somewhere else on your system. just in case.
FileJockey
Where is that external plugins folder and how would I force Pitstop to install there instead of the hidden folder?
Joe
I actually tried that on my first install of Acrobat DC and when I restored the Acrobat XI folder afterwards Acrobat XI would not launch and I had to re-install it. So the install affects more of Acrobat XI then what is in the application folder.
almaink
I think you need to also remove all the stuff in the main Library/Application Support/ Adobe/ then any folder named Acrobat for your version. Do the same for user/Library/ Application Support/ Adobe so that stuff isn't overwritten. It's getting to be a PITA to install stuff anymore as they put stuff all over the place now. This should work, although I haven't tried it because I won't be installing this new version myself.
prepsdk
Cannot see selected tool in Acrobat DC
A'm I the only one that cannot see the selected Pitstop tool i Acrobat DC?
In Acrobat XI the selected tool was marked with an emboss, but not in the new version noting indicates wich tool is in use.
That is really annoying.... :mad:
I guess it's another compability issue or?
Joe
Yes I've noticed it too and yes it is annoying. It seems to only be with the Pitstop tools. The Acrobat tools turn blue when they are selected.
What's In Your Warehouse
What's In Your Warehouse? Are You Sure?
In an average week you process what, 50 jobs?100? 150? 200? Let’s say about half of each job hits the mail or goes out to the customer. The rest goes to shelves in your warehouse so it’s ready when the client needs it. Juggling all this—and making money from it— requires Link to Article
