Printing on cardboard
slimbh
We have Konica c1085 and we want to know if we can print on cardboard 320 or 350gr grey back for exemple ?
Give it a try, what do you have to loose? I run 15mil magnet material through my Xerox 1000i.
Craig, is the magnet you are running from Magnum where you have to magnetize after printing?
What brand are you using?
What settings are you using on the paper catalog?
Thank you in advance for you info.
Yes it is DigiMag Plus 14pt. Set to 350gsm as gloss with the fuser bumped +10, side 1 bias is at 110. We have run thousands of sheets without a problem.
