Printograph Experience
kdw75
We have used Printograph for orders that didn't make sense to do in-house in the past and have always been happy with the quality, though sometimes not the speed. I ordered an envelope the other day for an out of state client and had it drop shipped. It was a simple return address with a PMS 109 bar. The customer called complaining. They had run the 109 bar in what appears to be PMS 123. Granted they run all of this in process, but 109 matches pretty well. We called and they re-iterated that they do not color match, they run pleasing color. We have gotten this job in the past and they always did a great job. It surprises me that with their state of the art Speedmaster presses, they would have such variances.
keith1
I have no experience with Printograph. I've used 4Over in the past and primarily use Sina. 'Pleasing colour' is the pleasing catch phrase. However I believe both these companies (Sina for sure) updated calibration 3 or 4 years ago for their offset machines. Since that time I've had very little issue with their colour output.
You mention you ordered envelopes. Does Printograph convert envelopes from sheets? If not, it's possible the envelope was run digital. Therein could be the problem. It was likely digital if it was a short run.
Good marks to 4Over here. They will print envelopes offset (on nice 70lb offset) & convert them. On the other hand if I was to send envelopes to Sina they would be printed digital and colour would be a bit of a crap shoot - it would be 'pleasing colour'. Note that if you were to order a small run from 4Over and have them run offset if will be more expensive. You're given a choice, offset or digital.
alibryan
I think you may be surprised at how often some of these companies actually do perform color calibrations on their presses. I know for sure that some of them perform it regularly enough that they’re always in compliance with industry standards. I guess they understand how important it is to have all of their machines printing close to the same way, day in and day out. It’s still not a guarantee of perfect color every time, as operator performance plays an important part in that process, but it definitely helps.
kdw75
They run them flat and then convert them.
Jeff_Guevara
I previously worked for ASAP Printing for 11 years which was purchased by 4Over in 2015. We were a GRACoL G7 Master Printer. While the presses are maintained, fresh blankets and rollers are regularly installed there are always variations from press to press and from run to run. Inline densitometry is widely used and checked around every hundred sheets or so. That said, there will always be variations when running high speed, high volume jobs day in and day out. This coupled with the fact that the values in your files are actually evaluated and altered with software to allow for more consistency means that pleasing color is actually going to be the best that can be obtained in a gang-run situation. Everyone wants the least expensive product with the highest tolerances they can achieve but if you must truly have something match color it should be run as a standalone project where you have complete control over the printing processes used, equipment and with attention to the output with the needs of the customer in mind. Of course, it will cost more. If you are using Printograph or 4over it is all about the pricing. You get what you pay for.
alibryan
I won’t say too much about it other than I was from a different location (and name), and probably also from the other side of the coin as far as product production goes. I found their company SOPs to not only be in and above conformance with industry standards, but in some instances I couldn’t imagine them being any better. Spare no expense, get things right, everything as good as it gets.
Canon Research
Canon
Navigating the New Customer Landscape
Enhancing the Print Customer Connection (Part 3)
Read All About It
