Quark Composite Workflow
pcmodem
Registered Users
We have been using a separated workflow for years and are now switching over to a composite PDF workflow.
Here is my problem. I have an Illustrator eps file with spot colors. The Illustrator file is placed into Quark 6, 7 or 8 and the spot color check box is not checked. When we print separated the output is CMYK with no spots. When we print or export composite, the output is CMYK + the spot colors in the Illustrator eps.
How do you handle this?
