re image backup jobs in agfa rip
Poul82
we are back up our jobs (the tiff files created by backup modeule) in apoge pdf rip and copy it on dvd
now when we are trying to reimage it by copying it on hotfolder
we give us a flush error and move the job to error folder
any idea ?
baggie
Re: re image backup jobs in agfa rip
It's a while since I looked at one of these but you cannot put the tiff files into the hotfolder and process them through the RIP. The Rip will only process PS or PDF files. You need to place the entire backed-up folder into the 'to be imaged' folder of the rip. Your folder structure will look something like this:
Job1234myjob\1\cyan.tif etc. where Job1234myjob is a folder with the name of the original job, then inside that a numbered folder for each page or signtaure, then inside that the actual TIF files e.g. cyan.tif, magenta.tif etc.
You can normally find the 'to be imaged' folder inside the 'Raster Jobs' folder which will be inside the 'ApogeePDFRip folder - make a shortcut to it on the desktop or somewhere useful to make life easier - hope that helps
baggie
Poul82
i put the all dir contains bitmaps in the "to be imaged " folder nothing happend
i try to copy the bitmaps in raster data folder the the bitmap have a extesion like reimage or previw when run the command reimage it's give me and error
Laurens
I haven't used a PDF RIP in years but I just finished checking the manuals: you should be using the 'official procedure' to re-image back-ups, with the additional contextual menu's.
I do seem to remember that there was a work-around to image just about any TIFF file but have you first of all tried sticking to the procedure outlined in the manuals?
Color Optimized?
Ink
by Noel Ward, Editor@Large
Color is in demand in all types of documents, making color management a critical part of Digital Printing 5.0. Managing color on one device/press can be an easy task with the correct tools and processes. But managing color to ensure printed pages are consistent and repeatable across the different substrates and color gamuts of toner and inkjet can be a much bigger challenge. Properly implemented color management workflows can help achieve consistent color results across multiple devices. Although many end-customers are claiming satisfaction with “pleasing color,” two challenges are still in play. Link to Article
