Recommended 12 station collator?
dagoof
Hi all,
I'm looking for a SRA3 12 station collator, likely be handling coated digitally printed stock - don't have a big budget though, so will be scraping around the used market! Would the Horizon AC1200 do the job (friction fed)? Any machines I should look at/avoid?
davidspiel
Hi all,
You are better off finding a heavy duty collator-- not a tower collator. A heavy duty, floor model collator will last you for decades. You can see some here: Reconditioning Process
TY
David Spiel
davidspiel@spielassociates.com
dagoof
Hi David,
Thanks, unfortunately I don't have the room (or likely budget) for a floor model like that!
Spoke to someone regarding the work it's required for and they reckoned a suction tower model should do the job?
Eighty7
Yep, I think you are going to need a suction feed collator for the stock you mentioned. Tower models will work fine with typical paper stocks.
Since you already mentioned Horizon, the VAC-1000 and VAC-600 series are solid machines.
