Riso Error Code
earljazz
This is my first post. I hope I'm in the right area. I have a Risograph RZ 390UI that I use primarily for printing #10 envelopes. It started showing an error code d-04-534. I was wandering if anyone has had any experience with this problem.
Thank You
Errors d-04 usually have to do with the rf tag on the ink canister not being recognized by the machine. Did you put in a new tube of ink? If you use a generic brand sometimes the machine will not recognize the tag. Pull the rf tag off the old canister that worked and stick or tape it onto the new ink canister in place of the one that's on there. Hope that helps???
