doubting_thomas
Recently we've been seeing some scratches on our
plate material, after imaging, as it works it's way through
our DPX activator and stabilizer tanks. The pattern runs
front to back on the plate, and the lines are the same distance
apart as the raised areas on the diamond plate that guides
the material through the paper path. Side to side it's uneven
as to where the scratching occurs. Has anyone seen this
type of scratching before so I can narrow down the areas
to look in. The scratches are just enough to remove a little
of the image, not strong enough to actually show up on the
unexposed material itself. It's more pronounced the further
down the plate, also. We're using Mitsubishi 8 mil Silver
Digiplate material in the DPX. I'm sure it's from the
diamond plate, or from something that has the same
distance from peak to peak as the diamond plate.
Any help would be appreciated, as well as a point in the
right direction.
right direction.
