Spotlight not finding some files
LoneGoose
Spotlight isn't finding some files/folders on my hard-drive. It seems like a random selection of about 20% of files it won't find. On such a file, even if I type it's exact name into Spotlight it won't find them. This applies to some files in my Documents folder and some in folders on the desktop.
Is there a way to 'rebuild' Spotlights 'index' or whatever it is that it uses?
I used to use TimeMachine but I haven't had that external hard-drive plugged in for some time now. Think it could be that? I could start using TimeMachine again and see if that fixes it...
Any insight would be helpful and interesting. Thanks!
By the way - OS X 10.5.8.
Nicolas
Thanks, David! The Apple Forums link lead me in the right direction. This simple procedure from the forums solved my problem:
System Preferences > Spotlight > Privacy... drag the boot volume into the list then delete it with the 'minus' sign. Spotlight then starts to reindex your hard-drive.
You may want to avoid spotlight all together and use a utility called EasyFind. It is much better and free.
Good luck
