Hello all,
I've been assigned the task of creating VDP templates using InDesign with the uDirect Plug-In for integration into our Printer Site Fulfilment (EFI) MIS. I have walked through a tutorial on the actual creation of the templates and have a pretty good handle on this part. BUT someone here told me that if I use CS3...the templates won't work with Printer Site Fulfillment because there is only support for CS2. This is a bit of a problem because we upgraded to CS3 almost immediately upon release. Has anyone else heard that using CS3 and uDirect wont integrate into PSF? I believe PSF was originally a part of Hagen OA which is now part of EFI. I find it difficult to believe that you can't use the most current version of InDesign to accomplish this.
Can one of you kind, knowledgeable folks help shed some light on whether or not this is true and if it is, why?
Any other tips or tricks you can pass along with regards to this task would be much appreciated also!
Thanks in advance for taking the time to read this
